MopedRyder
CURRENT STATUS
NO LONGER UPDATED - PLEASE GO TO NEW THREAD FOR LTE FIX:
http://androidforums.com/virgin-mob...le-apn-fix-wip-cm-aosp-4-4-x.html#post6516416
This is a work in process.
Currently we have working 3G (CDMA / EvDo) with both MMS send and receive working on CM / AOSP / TW ROMs. Some have reported working LTE but for best results use Hangouts for MMS is send or receive.
and / or
Virgin mobile working on Sprint networks when it comes to MMS messages is an over complicated issue caused the providers. We looked at adapting MMS.apk code to try and fix the MMS receive issue, but after they integrated Hangouts with MMS (with new 4.4) it appears to have worked itself out. When attempting to receive MMS on LTE networks with stock MMS or some 3rd party MMS apps it returns with a "HTTP error: Authorization Required". We are finding this is becoming common. We are trying to solve the LTE issue, but don't hold your breath.
This mod will:
1. Search and edit appropriate lines in build.prop
2. Reset the telephony databases (first boot will take a few)
3. copy correct apns-conf file
Directions:
Flash ROM
Flash Fix
Boot
It may take up to 5min to connect
profit....
First boot may take a few minutes to bring up 3G symbols and get internet connection. The telephony database is being rebuilt - give it a few minutes.
OLD RELEASES (TO TEST AND TINKER WITH)
MOD#1 is oldest
https://www.mediafire.com/folder/mnwf1fpxij75j/Old_Fixes
(MOD#3) CURRENT D2VMU 4.4 / MK5 ***Reported to work best with 4.4 ROMs***
Use the #3 fix if you are on a Virgin Mobile GS3
(MOD#3.5)UNIVERSAL Virgin Mobile Fix (Should work with any Virgin CM / AOSP phone -- not TW based)
What I did is change the partition specific mount points of my D2VMU fix above with the google ones.
IE:
mount("ext4", "EMMC", "/dev/block/mmcblk0p14", "/system");
Change to:
mount("ext4", "EMMC", "/dev/block/platform/msm_sdcc.1/by-name/system", "/system");
I also removed the SimToolKit because it was from the GS3 VMU build. I loaded the above universal fix on my phone and flashed it. I suggest this used on 4.2 thru 4.4 ROMS CM / AOSP based ROMs only. Also use hangouts instead of stock for MMS messages.
MOD#1
MOD#2
Special thanks to:
junkie2100
punkmaxx
moonknightus
and / or
This mod will:
Directions:
Flash ROM
Flash Fix
Boot
profit....
MOD#1 is oldest
IE:
Change to:
MOD#1
MOD#2
Special thanks to:
junkie2100
punkmaxx
moonknightus
