Tokens210
Android Expert
Why is the MMS Proxy & Port 68.28.31.7:80 when Virgin Mobile is 205.239.233.136:81?
I can't send or receive MMS without using the correct VM proxy, and everytime I change it manually after applying your fix, it reverts.
There's different points if I recall what moped has said, one for VM, one for other android phone that simply use the Google ones
As for SMS and MMS you need to use a non stock app such as hangouts or handcent, evolve SMSor chomp
I just flashed the 3/17 CM11 with the older fix number 2 with zero iissues, I have 3g/4g and text messaging works fine, not sure about MMS as I haven't sent any pictures or a text bug enough to be one
