Root [Virgin Mobile] Phone says firmware upgrade error and cannot flash via odin
gumbyx84
I have run into a rather big problem. While trying to use odin to flash the newest TWRP to my phone, it kept failing. I disconnected, then powered off the phone to restart the process. Right now my phone automatically boots into Odin mode and says "Firmware upgrade encountered an issue. Please select recovery mode in Fies and try again."
Any idea how the hell I can try and fix this?
Still comes up with the error screen. Searched around online and found out I might have to reflash the PIP but have no idea where to find the PIP for the Victory.
All you did was try to flash a new recovery? There is a zip of twrp 2.6.3.0 that can flash in any version of twrp recovery. Just for future reference. But there are ppl much more skilled than I here that may be able to help. Can you boot into recovery? Try holding volume up when it reboots. Then you could use one of the stock backups floating around
