mudflap2020
how do you verify the md5(question mark) I never knew there was one in the first place!,
theres no difference between this and the d2vmu one right(question mark, because that one booted nicely in one shot no probs and the rom is nice the only thing different should be the kernel, which I can flash if I want from xda right
Speaking of dkp kernel, new test build is out. CM has unified their kernel, which means that there are no more carrier differences. Therefore, decimalman has created a new folder called just "d2" for his new build, which is flashable for Sprint (and by default VM/Boost), TMobile, Verizon, and AT&T.
Just a thought for @ajnycguy, I don't know how hard it is to incorporate Aroma installer, but it would be very cool to be able to do so and then give the user the option while flashing a ROM to go with stock, dkp, BMS, or LeanKernel. Just throwing that out there.
arty:
. Sorry guys.Speaking of dkp kernel, new test build is out. CM has unified their kernel, which means that there are no more carrier differences. Therefore, decimalman has created a new folder called just "d2" for his new build, which is flashable for Sprint (and by default VM/Boost), TMobile, Verizon, and AT&T.
.I'm going to eventually try and do this, the only thing is that, I don't know how hard it is either haha. I'm trying to learn how it works and how to set it up maybe, I could ask the created of MOAR. I believe it's @rompnit. Maybe he could guide me along the way, that would be cool.
Yeah forgot to suggest who to get in touch with, since MOAR does have that option. Just FYI, thread for dkp kernel had a lot of users reporting issues with the new unified kernel build. Nothing too major except for a couple of people with WiFi issues that I am not entirely sure can be attributed to the kernel.
I had this Wifi issue as well. If i remember correctly you said it runs with the newer versions of CM that don't care about the carrier when flashing a kernel. I was on the Snapshot Build when this happened. When I updated CM11 and flashed the new build it worked fine. So far i can say that I have had 0 issues. Maybe it has something to do with that?
Quite likely, in my opinion. If there really is an issue, decimalman is very responsive and fixes things ASAP. Would assume that CM has done a bunch of commits since the Snapshot that work with the unified kernel source, but that's just an educated guess. Also, I hear that a lot of Bluetooth issues were fixed on 1/21 nightly but borked again on 1/22, for what it's worth.
Good to know about those fixes... Since I have to wait to upload anyway, I can try to see if I can do the 1/21 build tomorrow as well. Thanks :thumbup:
