Root [Virgin Mobile] Samsung Galaxy S5 ROM for GS3
Ab5traktion
So, I just came across this ROM. It's LikeWise S5 | LT | Beta 2.5 | NE4 | ND8. From what it looks like, it's like running Samsung Galaxy S5 on the Galaxy S3. I came across this in an AT&T forum but it does say ND8, which is leading me to believe that our GS3s will be able to run it. I could be wrong. I actually don't have the ND8 modem on my phone, so I do feel kind of bad for not test running it first before posting it. I figured I'd put it out there if it is a ROM that can be used. Personally, I'm a bit partial to AOSP based ROMs (if you couldn't tell from my extensive lists). I'm hoping the ROM can be used and people can have fun with it.
7.2.14 | 4.4.2 | LikeWise S5 | LT | Beta 2.5 | NE4 | ND8
I can comfirm working
Haven't read past 1st page yet on xda thread. It's a 4.4.2 ROM yet States 4.3 modem and bootloader required. For a 4.4 TW ROM you need the ND8/NDC modem/bootloader. Yet screen shot above is with ND8 modem.
I've had the ND8 for awhile I just found out that the roaming indicator always stayed off and couldn't fix.I couldn't send text either.Maybe you advanced guys can fix it up for us.
Ok, so I have one question that's been nagging at me for a while: is it when worth upgrading to ND8? I didn't even upgrade to MK5, largely because of Knox. The thing is, I don't like TouchWiz based ROMs. Seems contradictory because I have a GS3. I greatly enjoy AOSP based ROMs, if you couldn't tell from my lists.
Does ND8 give you better signal? Or does it just give you the ability to run Android 4.4+ TWZ ROMs? And is there a way to upgrade to ND8 without having Knox? I know that's kind of a novice question. I just haven't been doing a lot of research because I've been focusing more on AOSP ROMs.
I've read too many bad things on the Boost facebook page and Sprint community forum about people complaining about worse 4G reception so I refuse to update. It wouldn't be a big deal if you could flash different modems but once you have knox you are forced to use the most recent modem (NDC/ND8.) Occasionally you see a post from someone saying they get better reception with the new modem but if you do a little research you will see this is far from the norm.
If you prefer AOSP then I would say don't do it. For one, right now you can change modems whenever you want. And two, you can truly unbrick the phone with boot off the SD card method if you really screw things up. Once you have knox you won't be able to do either.
So, if you want touchwiz and don't mind not having 4G in as many places go for it.. but if you want AOSP then HELL NO! lol. I'm sticking with AOSP, my MG2 bootloader, and being able to try any modem I want. **** touchwiz ;)
edit: Also there is a bug or something with ND8/NDC boot loader at this time where you can't charge the phone with it off when using AOSP based roms. The phone locks up and you have to do a battery pull. This only affects AOSP when used with the NDC/ND8 bootloader. Another reason not to update if you plan on using AOSP. More info on that can be found in the different threads on XDA.
I went to a back up I had trouble texting.I use textra all apns rite and flashed the fix.Other than that it was really really smooth.My data worked fine.
Ive been on nd8 since the stock came for it.This rom is smooth.Im staying if you don't have nd8 dont flash.Sorry I thought some would know.Please read all up on this nd8 stuff before you flash.
Please read before any flashing hate to see peeps brick just because I said rom is good.Always read read then read again.
If you need better help post in the Q&A we will help.
This ROM works great until I played a couple games I had trouble.Not sure what causes it but in a bowling game my tilt to curves my ball was backwards.
Also brothers in arms it was upside down.I'd tilt my phone and it would go upside down.
excuse me, I haven't been here in a while, can someone please refresh me on what the ne4 build is?, like what carrier.. and other info
Were you able to fix this? If so, how? If there isn't a fix is there another ROM that compares to this one?
Hey, just wanted to post that, after the ota from 4.3 to 4.4.2 on my L710 S3, installing SuperSu and Busybox, I flashed LiquidSmooth 4.4.4 (Which was fine. Running Carbon 4.4.4 now, also fine, and after the vpn fix for Virgin Mobile, have a strong 4g/lte signal with NDC, havent tried flashing another modem, so I can't say anything compare modems) but then carelessly flashed an international rom (had to do it eventually) and I was still able to unbrick by booting a recovery image off the SD, even after having Knox. I had disabled Knox in SuperSu while still on the stock rom, but idk if that is why I was able to do it. That seems too simple to subvert an eFuse and/or whichever part of Knox would prevent booting from the SD (I thought android had to be able to do that but Knox is changing a lot) but it did work for me, and allowed me to boot to download mode and Odin back to stock 4.4.2 firmware, so that is possible. I arranged an exchange for the phone after I thought I had killed it, so, what the hell, when I recovered, it was play time. I even went ahead and even flashed stock 4.3 MK5 and it took it and downloaded the ota again, although wouldn't install it (might have been a fluke since I have had that happen before), hence the 4.4.2 NDC flash. When I got back to stock recovery, I was able to Triangle Away back to official status, Knox not tripped, even after flashing non-TW roms, which I have also read shoud not be possible. I've flashed back and forth from stock to custom a few times now, and same results. I know my CarbonRom is running the same NDC baseband/same modem as the ota (thought I had a screenshot of LS, I think it said NDC as well, but cant find it atm to confirm) but I have changed the bootloader and still not had a Knox issue. Again, I went from 4.3mk5 to 4.4.2ndc (ota), rooted with towelroot> supersu> disable knox (yes)> busybox> liquidsmooth 4.4.4> FlashingDroid (don't do THAT; its for i9300)=brick> booted into download from recovery img on SD> Odined 4.3mk5 and achieved official status> Odined stock 4.4.2 (official status. Cant recall if I needed Triangle Away that time but got official)> flashed CarbonRom=no problems. Knox is confusing a lot of people, so I'm just adding this in case it helps.
Either Knox is still mysterious or Jesus built this phone. I want to try a debloated TW based rom when a viable one becomes available (I really just need working tether and hate non TW multi-window (Carbon's "floating" is just poorly implemented compared to TW) and I am hoping that this isn't just luck, but this phone is working 100% without knox problems.
I wish I could say the same for my Galaxy Note Pro 12.2. Knox is killing me on that thing! Its still stock! Holding my breath for an undetectable root for a bit longer...
