Root [Virgin Mobile/Sprint] [cwm][tool] zv5 build.prop, flashable .zip
baconsauce
Member
If you fellas ever get a bootloop for editing this file
It is just a cleaned zv5 build.prop, flashable through cwm, lte2recovery or copy/paste/rw-r-r-
After unbricking/flashing a rom, I noticed that there were repeats on some of the props. I don't know if it was a dev or sys error or even meant that way. Anyways all I did was deleted the "mistake" and got rid of the doubles. It works just fine either way.
Hope this helps
