Root [Virgin Mobile/Sprint] Help boost mobile bricked on update
UPDATED TO ZV7 WITH ZV6 PRIOR ROOT AN BRICKED MY PHONE TRIED EVERY UNBRICK METHOD AN I DONT SEE ONE FOR BOOST HELP ME AN POINT ME IN THE RIGHT DIRECTION PLZ AN THANK YOU :smokingsomb::confused::confused::confused:
clock work sorry been busy
I understand, the real world comes first. There's several boost owners having the same issues as you. I have been researching this problem and trying to figure out a way to make it work for boost. It's a little tuff when I don't own one myself, you understand. I've got same ideas I'm going to look into, though no guarantees. If I need testers can I count on your help?
Follow the VM unbrick method. This will return you to stock LG. Once phone connects and recognized as boost mobile the quick update should configure to v7 Boost as files are there.
If it boots as VM, then root, install CWM, and restore your nandroid backup.
Hope this helps
