Hello,
I've been reading around and I can't figure out exactly what info to follow and what not to follow. I know with my old phone I was told to never use factory reset if you have a rooted phone as it causes major issues.
So basically I rooted my LS720 (VM) and I'm wanting to know the best way to go about resetting it. I'm using the default rom (not using anything fancy) and will probably stay on that. Basically right now I'm having issues with my bluetooth disconnecting and reconnecting after playing a song, dialing and talking. So I'm hoping resetting it will fix it as I tested other devices and the bluetooth doesn't have that issue with them. I think it's an issue from when I was toying with apps to tether wifi via Bluetooth, but not sure.
Once I get it reset I'm going to unlock it again as the feature I basically use is being able to use Link2SD since the storage is so small. I've thought about using a custom rom, but not sure as I'm afraid I'll mess it up. Though if anyone knows of one that will let you for sure tether wifi from the phone to a tablet via wifi or bluetooth would be great, but I think VM pretty much locked that out altogether.
Sorry for the ramble, but hopefully someone might know the best guide/route to go as I'm not sure atm.
