Root [Virgin Mobile/Sprint] Need Help Replacing Stock Home Theme
jabstep12
Hi,
Unfortunately, I accidentally deleted this file/app ".com.lge.launcher2.theme.optimus" from my LG Optimus F3 using Titanium Backup Pro. Now text under my app icons won't show up. Can someone send me a replacement file? Is it even replaceable?
Any help would be appreciated.
Thank you in advance!
You can download the rom zip file depending on which version you are on LS720ZV5 or LS720ZV6 as V5, or V6 and unzip the rom zip file. Navigate to the /system/app folder to grab the file you are looking for. Then copy it back onto your phone to where it was deleted.
Just download one as you would any apk. Use a file management app to install it, or use your stock downloader. Then go to Home settings, and change your theme.
