Root [Virgin Mobile/Sprint] odexed v6 and now no GPS???
nyktovus
Member
so i updated to the odexed v6, and now the gps /navigation function is toast... i search for a location and it just spins and spins..
help??
help??
What were you running before the update? Was it de-odexed v6/v5? Did you flash the odexed v6 in cwm recovery or did you use the unbrick method? If from recovery did you wipe dalvik-cache before rebooting? Need more info, please. :)
Was using the stock v5 that came with the fone. Used the motochop to root.
Switched to odexed v6 when i couldnt get the update warning to relax.
All is well but gps and maps return a "search failed"
Did you turn on gps? I'm sure you did. Sometimes you need to turn it off and then back on again. Weird your having issues with it.
I hate to tell you this but you're about to go through it again with the new zv7 ota update that just came out. No telling when you will start getting the new notification but it should be very soon.
do it all over again with v7?..
good.. cause i fear i'm gonna have to do this all over again anyway.. might as well be for a whole new version/reason/release.
lets pray this one works.
