Root [Virgin Mobile/Sprint] Pre-built kernel?
xclusive36
Android Expert
Can someone compile the kernel for this phone for me? I'm having issues with it. I'm looking for a compiled non loki'd kernel for the Optimus f3.
The LG Source is: HERE
I'm looking to get the cyanogenmod rom to boot and I think that's one of the things that is holding me back. If I can get someone to build a kernel for me, I can focus my attention on the other issues on why the rom won't boot correctly.
If you can help me out, I would be very grateful.
I was looking for a pre-built kernel to include with the compile. I've used the source kernel I got off of github. I have tried to build it by it's self and also tried to build the kernel source received from lg's website and both fail.
I'm not able to build a kernel on my own at the moment. I was hoping that someone else may have better luck than I do.
It also has some issues.
One being the phone data connectivity. It doesn't always work. I haven't figured out why.
Two being the trebuchet launcher disappears when the virgin mobile software installs. Defaults to the stock launcher.
It's not a 100% cm rom, at least not currently. I am merging the source built rom I compiled (which didn't boot) with the stock rom loonycgb2 created. Hence the workaround.
I'll release a alpha version soon.
