Root [Virgin Mobile/Sprint] [Recovery][VM]CWM Philz Advanced CWM for the LG Optimus F3
xclusive36
Android Expert
Philz Advanced Edition 5
CWM for the Virgin Mobile LG Optimus F3
* CWM Version 6.0.3.7
This is an older version of CWM: 6.0.3.7
This is a non touch version of CWM
I couldn't get the touch version to work.
To use, you must use the volume keys to navigate, and use the power button to make your selection.
Philz Advanced Edition 5 CWM gives you a few more options than the standard CWM.
Source: https://github.com/PhilZ-cwm6/philz_touch_cwm6
  • Secure recovery lock with passkey
  • browse phone with root access using full GUI in Aroma File Manager
  • terminal access from recovery with root access through Aroma File Manager
  • Multi Zip Install menu: check multiple zip files to install in a row
  • Custom Install Zip Mode: set a default folder to start with + browse backward up to the root
  • exFAT, NTFS and Ext4 support in recovery for external storage through kernel modules for many devices for faster write speed
  • TWRP backup and restore support, include full md5 sum support (single and multivolume, compressed and non compressed formats)
  • Advanced statistics during backup operations shown in color: total backup size, backup size progress, backup time, compression ratio...
  • support .android_secure backup/restore from external storage
  • optional reboot after custom backups/restores
  • sd-ext support (ext4)
  • nandroid backups support /preload in backup and restore jobs (custom and stock modes)
  • nandroid backups support /misc in backup and restore jobs (custom mode)
  • devs: 5 extra optional partitions supported in nandroid operations by editing recovery.fstab
  • set special nandroid settings: time zone, toggle md5 check for lightning fast backup and restore, toggle /preload backup and restore, enable nandroid compression using pigz (multi-cpu gzip compression) and choose ors backup target volume
  • recreate md5 sum check for your cwm backups for compatibility with stock CWM if you need to revert
  • cancel nandroid operation with back button
  • create custom_rom.zip from current ROM or from a pre-existing nandroid backup (based on boot, /system and optionally /preload)
  • nandroid backup path auto-renamed with current ROM id from build.prop (ro.modversion, then ro.romversion, then ro.build.display.id)
  • custom backup and restore job list: backup and restore freely any partition combo (include modem and efs)
  • backup/restore EFS in both tar + img formats, now with time tags for both tar and .img
  • support flash modem.bin image files in addition to custom modem.img files, now support for multiple *.bin versions under dedicated folder
  • during custom restore, you can see the contents of the folder you want to restore from
  • delete custom or TWRP backups from recovery menu
  • full wipe before flashing new ROM: wipe user data + format /system and /preload. SD card content is not affected
  • full support for openrecovery script specifications include all backup and restore options
  • run openrecovery scripts in 2 modes: on start goomanager boot scripts + one touch menu to either directly open a default path or freely browse for scripts
  • define ors backup target volume from within Nandroid Settings menu
  • ors backup/restore in stock clockworkmod or TWRP modes
  • advanced power options menu
  • detailed build info in About menu
**Your phone needs to be rooted
DOWNLOAD:
You can Download it here
This link points you to multiple files, make sure you download the correct one!
The Download is for installing on Windows. Follow the readme file that's included.
now can this be used for which firmware? zv5 & 6?
edit: for that matter zv7. and i guess through the windows installer it works on all firmwares
Very nice!! I prefer cwm but it is always good to have choices! Keep up the great work xclusive!
This is not to be a better recovery than any others posted on this forum, It's just an alternative. I compiled it for fun.
Credit goes to Philz for all of his hard work.
Is there any way to install this without a computer like how you can on CWM touch?
extract the zip file, under the files folder you will find a bunch of files. The ones you need are:
aboot.img
Philz-recovery.lok
aromafm.zip
Copy aromafm.zip to either your internal sd card, or your external sd card. It must go into this folder
/storage/sdcard0/clockworkmod/aromafm/
or
/storage/external_SD/clockworkmod/aromafm/
copy both aboot.img and Philz-recovery.lok to your internal sd card to this folder
/storage/sdcard0/
Run these commands inside of a terminal app. Any Terminal app will do.
  • dd if=/storage/sdcard0/aboot.img of=/dev/block/platform/msm_sdcc.1/by-name/aboot
  • dd if=/storage/sdcard0/Philz-recovery.lok of=/dev/block/platform/msm_sdcc.1/by-name/recovery
or
Cwm is telling me I don't have the aromafm.zip. I had to put it in clockworkmod/aromafm/ instead of clockworkmod/aroma/
Thanks for the instructions though!
