This ROM is deodexed!! This is not a bad thing but if you do not want a deodexed ROM Do Not Download
VERSION 22 IS OUT NOW, CLICK HERE TO GO TO THREAD
This ROM is based on the V7 update by xclusive36.
Here is what is working:
Everything.
Here is what is not working:
You tell me, I am currently testing now.
Here is what is removed from the ROM:
This ROM is a ~265MB Download, and leaves you with over 1GB of usable space for apps and downloads BEFORE google runs updates in the background (which happens almost immediately after getting a network connection. . I know this is not the best, but I slimmed it down literally all the way without losing too much of the LG Stock feel, and including a AOSP/Google experience to it.
Download:
AdvancedStock7 - Version 20 (Fixes Update Profile/ PRL issues from previous version)
** By downloading this ROM you agree that anything that happens to the device, be it negative or positive, is your own fault.
ChompSMS MMS Settings:
MMSC: http://mmsc.vmobl.com:8088/mms?
MMS Proxy: 205.239.233.136
MMS Port: 81
Getting rid of the "Update Device" Error on bootup(Might not work?):
These supplemental packs include any removed apk files for you to install if you need or want them (Wouldn't see why, but I know some of you will ask)
LG_SUPPLEMENTAL_PACK2.zip (Includes all LG, Sprint, and Virgin Mobile Applications that where removed.)
Any questions let me know!
All Downloads can be found at my download center: LG Optimus F3 Download Center
To Install:
**NOTE: DIRTY INSTALL ONLY IF YOU ALREADY HAVE A PREVIOUS VERSION INSTALLED!!!!!!! YOU HAVE BEEN WARNED!
Steps to do an activation:
Some things to note:
Things to come:
Screenshots:
In the attachments!
Issues with Links2SD? Read this post:
Post number 103
Looking to donate? Click Here!
Everything.
- LG Bloatware (Except what is required by the ROM to work)
- Sprint crapware (e.g. Connections optimizer, VVM - Visual Voicemail, and system app installer)
- Virgin Mobile Application Downloader (When the phone first activates it downloads a bunch of crappy themes, and unneeded files.)
- Dictionary
- Useless google play stuff (Books, Play Games, etc. Google play is still installed with google services framework)
- LGFOTA.APK removed (Possible no more OTA Notifications?)
- LGUSMMS.APK - (LG MMS APK)
- Q-Slide and Q-slide notification floater.
- Any other bloat I didn't like or need
- SuperSU (Added by xclusive36)
- CM Browser (Not CyanogenMod, it is CheatahMobile)(This is a lightweight (1.5MB) browser)
- ES File Explorer
- WiFi Hotspot hack by emkeene
- AdAway Added for Ad blocking power!!
- Custom Boot Animation and Sound
- ChompSMS
- Apex Launcher
- Android Terminal Emulator
- init.d emulator(sandix)
- SDCard Swapper Fx3 (Sandix)
- OpenOTA (Sandix)
- Built in SD Card Swapping!
- Overclock!! MAX: 1.8GHz (Recommended: 1.2GHz-1.4GHz with ondemand governor and noop schedular)(Thanks to robaho for the Overclock Kernel Go send him some love for his amazing work!)
Download:
MMS Port: 81
- After booting up, login to the play store
- Click this link on your phone, (Or install from Play store on Computer using googles Install OTA service)
- Find "Update Device" in the list
- Disable both check boxes.
- Reboot phone and the Error should be gone.
- Reverse these instructions to do the PRL/Profile updates if needed.
To Install:
- Download to internal or External SD Card.
- Reboot into CWM (HAS TO BE THE TOUCH BASED ONE)
- Format Cache
- Format - Factory Data Reset
- Install Zip
- It will reboot on it's own
- Once it boots, let it sit for about 5-10 minutes to configure apps, etc.
- Reboot once more (So profile updates will work)
- Before doing anything, go to settings -> System Updates -> Update Profile
- Reboot
- Then go to Settings -> System Updates -> Update PRL
- Reboot Once more
- Add Google Account information
- Install your favorite 3rd party apps
- Enjoy the ROM!
- Format Cache and Dalvik Cache
- Install Zip
- Reboot
- Reboot Once more
- Enjoy the ROM!
- Make sure the ESN AND IMEI number are on your Virgin Mobile Account
- Turn the phone on
- goto settings
- goto activate device
- let it fail out and repeat step 4 two more times
- then update PRL and Profile
- Turn the phone on
- goto settings
- let it activate and then reboot
- verify that you can make calls, SMS, and got data.
- Flash AdvancedStock7, making sure to wipe data, cache, and dalvik cache
- Once AS7 is booted, go to settings, System Updates, and update the PRL and Profile, then reboot. You should now have SMS, calls and Data working.
- Some options in the settings will crash, this is normal as I removed the apk file they relate to.
- Sprint Connection manager is removed so that option will not work.
- Lockscreen settings will not work (There are apps on google play to mess with lock screen settings)
- I did not add the swap SD Card script from androidguy1991. This is because that script would have been complicated to add to the ROM zip, you can still add it though if you feel you need it.
- Every time the phone boots up, you will get a force close error with LG Updates, this is normal as I removed LG Update from this ROM.
Things to come:
- Possible upgrade to V8 of the Virgin Mobile LG Stock ROM.
- On boot, Grant Uninit.d root access, this allows it to make the proper folders and files for init.d emulation.
- under /storage/sdcard0/init.d put all the scripts you want to run following alphabetical patterns for priority on boot. (1_FirstScript, 2_SecondScript, etc.)
- reboot and watch your scripts run without any effort!
Screenshots:
In the attachments!
Post number 103
