Root [Virgin Mobile] Stock Virgin Mobile 4.4.2 KitKat rom?? Please help
prime0025
Hey, so I had just recently gotten this phone. I was able to root and flash cm11 w gapps onto it. I have decided that I would rather stick with the stock 4.4.2 kitkat rom that came with the phone. I made a backup of mine using cwm 6.0.4.5 but I always get "Unfortunately, the process com.google.process.gapps has stopped" when it boots up and I can not get rid of that message. It just keeps popping up and does not let me do anything on the phone. Is there a way I can get rid of this message or is there somewhere I can download a clean version of the stock 4.4.2 kitkat rom? Any help would be greatly appreciated. Thank you.
Would flashing a different recovery then trying to restore the back up make a difference?
A backup should be restored with the recovery that made it. You probably need to wipe internal storage and factory reset before restoring your backup. Your coming from cm back to touchwiz.
There is a zip for returning to stock but its NDC. There are a couple different KitKat stock builds. Look at build number. If its NDC you can use the zip or just Odin the stock NDC tar.
stock tar
stock zip
Both NDC KitKat 4.4.2.
If your build is nj3, do not use the tar for Odin.
stock tar
stock zip
Thanks a lot. I am new to this phone and still learning. How can I check if my build is NDC or NJ3?
Settings/more/about phone, When you restore your backup. Look at build and baseband. Last 3 digits.
If it NF4 you have the triband. It's very different.
hello goodnight friend have a problem with a team L710 mobil samsung sph BOSST the computer has voice messages but can not set the apn can not browse any means just for wifi equipment already routed with a rom from canada but I have data 3g cdma team who could assist me with any suggestions I will be very grateful for any help you can provide me friends.
the team has this ro, factory
version of software L710TVPU0ANF4
thanks in advance
thanks in advance
https://www.androidfilehost.com/?fid=95854736883843092 Here's the link to the L710TVPU0ANF4 stock tar, Your Welcome
