mogulbuster
After rooting my phone and doing some searching around the forums on increasing my Galaxy Victory's storage I decided to try an app called Root External 2 Internal SD (https://play.google.com/store/apps/details?id=eu.codlab.int2ext&hl=en)
I played around with this and a file explorer to locate the correct paths, and changed the app's settings accordingly. In the end I ended up successfully swapping my SD card's storage so that when I look in Settings>Storage my total space is listed as 29.71 GB (my external card) with 27.66 available.
However when I cannot install more than the standard 2 GB of apps to the phone. In Settings>Application Manager it still displays my device memory as 1.7 GB used and 135 MB available.
I would assume that the app I used told the phone to use my external as internal and vice versa, but failed to change some system limit set at 2 GB. Does anyone know a way to change this? Is there even a possibility this could work?
For anyone interested the paths I used for the app were:
-Original internal: /sdcard/
-Original external: /storage/extSdCard
-Ext. SDCard device access: dev/block/vold/179:33
Any help would be greatly appreciated!
