Root [Virgin Mobile] Systemui Failed ????
Has anyone gotten a system ui fail. on cm11 nightlies. the system ui failed so i rebooted it 3 times then it worked again any solves
Maybe bad flash or download did you do a dirty flash over a previous version
Its cm11 . on galaxy s3 . I had stock then went to recovery wiped cache data and dalvik. Then installed from zip . the software is starting to lag bad. Sometimes in the beginning it didn't but not it does any ROM you reccomend that works and is cool looking
I have been very impressed with SOKP. I'm currently running the July 31, 2014:
Sonic Open Kang Project
I've had it happen, but I always believe it was due to the fact that I altered the status bar with xposed framework
Never had to restart the phone tho, phone typically says systemui failed to start 3 times in a row, while its saying it I get no status bar, but after The 3rd message status bar starts and all is good
Usually only happens during boots for me personally, I believe I started happening with the m6 or m8 or whatever snapshot build
