Root [Virgin Mobile] texting failure
My texting was working this morning. I go to text a while ago and it said text failed. I tried a different persin and the same thing. Help please.
You can try turning data off then back on or rebooting your device. If that doesn't work, the try updating profile/prl under settings/system update
try clicking on that exclamation point next to the failed text and then just select to retry sending. I get that pretty often when I'm in places with very low and almost no service.
