BigBossman
Okay so since most of us are coming from the Evo V you'll already know what I mean by this. For those of you who do not know what this is allow me to explain. There is a method to take the Virgin Mobile Evo V and essentially change the radios to that of the Sprint equivalent Evo 3D making it run on Sprint's Radios. In simple terms it makes the phone have better signal receptions and allows the flashing of Sprint-Based ROMs without complications such as data not working because the phone is "running" on Sprint. My request is that a Dev should do the same with the S3 (if it is possible) so that we would have better data connection and can flash Sprint S3 ROMs without issues; a VM S3 to Sprint S3 Fix Everything Mod
Edit: There are also methods to disable Throttling (Soft Data Caps) and add network hacks if anyone knows how to do this it is also appreciated. Like a flashable zip of this http://www.androidpolice.com/2010/1...riers-data-throttling-on-your-android-device/ there is a folder under data/system/data/-> called /throttle/ and I'm wondering if deleting would do anything?
