Root [Virgin Mobile] Warning about flashing kernels
xthedakmanx
Android Expert
As of 7/29/2013...Will update when there is progress on this issue.
This is a notice to EVERYONE who has CWM on their phone as of right now.
(Atleast the version in this thread)
Be EXTREMELY careful flashing ANY kernels in recovery at this moment unless they SPECIFICALLY say they are for the Virgin Mobile varient! It will 100% BRICK YOUR PHONE! AKA, no turning on, nothing. The only thing you will be able to get will be QHSUSB_DLOAD in your device manager when plugging your phone into your computer, and there has not been a workaround yet for this specific phone.
The issue seems to be how third party kernel zip's flash
In the install script, it goes through and tries to write the boot.img to /dev/block/mmcblk0p5, when it should actually be at dev/block/mmcblk0p7. Until a fix/workaround has been figured out, be VERY careful on what you flash on your phone!
Any idea why the kernel that came with this ROM didn't brick my phone
Because the developer used by-name to flash, thus correctly flashing the rom for your phone. It installed system to system and boot to boot. And since its the same hardware it boots :)
Even with aboot gone you should still get to odin mode. You should worry about tz(mmcblk0p8) which is right before aboot in the boot sequence.
is there a recovery that will work correctly or is it more a case of the script. could someone simply edit and flash it.
You'd think so, but nope >_< TOTALLY locks up the phone.
What was happening was I was flashing for the wrong kind of GS3 (derp), but still, like you said, it STILL should of booted up....but I couldn't even get into download mode
I stupidly flashed the Yoda Kernel for the Verizon GS3. It shouldn't of totally broke the phone, but for some reason I couldn't even get into Odin mode or recovery
