Root [Virgin Mobile] Working 4G on Sprint ROMs
notebooko
So has nobody found a way to get 4G working on Sprint ROMs? I'm currently running the M.O.A.R and 4G isn't working. :confused:
We're having issues on aosp and aopk Roms. Be patient. Synergy Rom runs 4g though. About the only working one I've ran. Careful with flashing right now.
Hmm.. The ROM I'm currently running is TouchWiz based and 4G doesn't seem to be working. Is there a fix that has to be applied or some network settings changed?
I have working 4G on my Galaxy S3 but lose the ability for MMS. After some looking around other forums and xda I have found the APN that enables MMS but only on 3G but there is no connection to LTE.
Name- Global Roaming - SPRINT
APN - cinet.spcs
Username - Sprint
Password and sever are both marked as an * not sure what "*" stands for.
MMSC= http://mmsc.vmobl.com:8080/mms?
MMS Proxy- 205.239.233.136
MMS Port- 81
MCC- 310
MNC- 120
APN Protocol- IPv4
APN Roaming protocol- IPv4
Bearer- Unspecified
You can get 4g working, but you'll lose mms. Or you can have mms, but lose 4g. Be patient. Roms are coming.
Prepare yourself, roms are coming
After much testing I have found it is possible to have 4g LTE and MMS. The only thing is you need the correct apn settings and mms will not work with 4g on or connected. If you go to the testing menu you can see your current connection. If it is LTE or erhpd it will not send or receive but over evdo it will. So you need to toggle 4g on and of for it to work. I could upload the apn if anyone needs it.
EDIT: I am running moar rom
Does that work for AOSP roms?
have you tried using the stock messaging app?
Could you please upload the apn? I installed M.O.A.R. rom but i have no 4g.
This rom is soooooooo awesome. If I can get 4g working I think I'll stick with this rom for a while.
Thanks!
Anyone running a sprint TW ROM that doesnt mind testing out what I think will fix LTE please post your Sprint TW ROM. (link to the xda page on it even better)
I will have you flash a update that will replace your kernel, possible apns-conf.xml file, and build.prop to enable LTE again. Based on Building my ROM with a Sprint kernel I have a theory.
You would have to make a nandroid backup, flash my update and test. If no work - restore your nandroid.
I have the moar rom running on 4g and 3g but I cannot get the mms to work because I think I need the msl for my phone (Which I feel is impossible for me to get at this point.).
[QdefinitelyedRyder;6140065]Anyone running a sprint TW ROM that doesnt mind testing out what I think will fix LTE please post your Sprint TW ROM. (link to the xda page on it even better)
You would have to make a nandroid backup, flash my update and test. If no work - restore your nandroid.[/QUOTE]
I need this if it works still dont have 4g...
I need this if it works still dont have 4g...[/QUOTE]
What ROM are you on?
