Anybody having problems with angry birds and vituous 2.7...I like the ROM so far but I cant get AB to work and I have had many app updates fail while updating.
Any ideas?
Any ideas?
Had that too with the stock kernel and 2.7 but flashed King BFS#4 and it works fine now. I've also had a couple apps that failed to install from market (adobe flash update for one) but I went to the /system/app folder and deleted it, then just reinstalled from the market and it worked fine after that.
Virtuous 2.7 with custom conservative Kernal runs angry birds fine. Issue is it will not run on EVERY launch without tapping screen or doing circles on screen when loading.
The odd thing is, even when my inc was stock/unrooted I had this problem. Now that I'm rooted and running hydra 1.15 I still have the problem. You just have to try downloading it a few times, it's really annoying.
