Virtuous Widgets
El Presidente
Beware The Milky Pirate!
If you like the Sense Lock Screen (I do), but get annoyed at the fact it's not very customisable, check out some of these apps by The Virtuous Team. They should allow you to add widgets and theme the stock Sense lock screen without the requirement of root. :)
Nice find, is it a replacement lockscreen like Widgetlocker or does it allows you to customise the current HOX lockscreen without replacing it?
I'd imagine the former.
Looks like a lock screen replacement actually, I thought it was the latter and just added a bit of customisation, but no.
Still worth a go, I found WL was pretty laggy at times, especially when using the Sense 3 theme.
Yeah I found all lockscreen replacements to be laggy, especially when you turn the screen off and straight on again you usually saw the original lockscreen first, something to do with Android security.
