Anbazhagan.R
Hi,
I am executing the CTS Testcases in new mobile platform.
The issue I face in execution is:
When I try to run a individual package,
ie android.core.vm-tests, it is not running successfully. (Only this package throws error, others are working fine)
Command used: start --plan CTS -p android.core.vm-tests
And also when I tried the same in Reference phone, it also throws same error.
Error Message shown:
Test package: android.core.vm-tests
dot.junit.opcodes.add_double_2addr.JUnit_Test_add_double_2addr#testB1...Exception in thread "Thread-12" java.lang.NoClas
sDefFoundError: junit/runner/BaseTestRunner
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(Unknown Source)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$000(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at com.android.cts.HostSideOnlyTest$HostSideTestRunner.run(HostSideOnlyTest.java:49)
Caused by: java.lang.ClassNotFoundException: junit.runner.BaseTestRunner
... 13 more
The CTS version using is 2.2_r2. The android build too is 2.2 version.
Is there any precondition which needs to be done to execute this package..?
Thanks in Advance.
//Azn
... 13 more
Thanks in Advance.
//Azn
