Help Vodafone 858 (Huawei U8160) update
Bomshika
Hello all,
I'm new to this forum, decided to join as Vodafone are useless in assisting with anything. I bought the vdafone smart 858 awhile ago... A good starter smartphone. Awhile ago, it told me that there was an update for it so ofcurse i went to install it... It downlads properly as far as i can see and then tells me if i want to install now or later, The phone will have to restart itself to install the update... So i click ok, the phone never restarts itself, I have clicked both options and nothing, i even tried turning it off and on to see if that will work, it didn't ofcourse
Can anyone help me? As i said Vodafone are useless and told me to check the manual... The phone didn't come with a manual only a pamphlet thing and that has no info on it
Thanks bom
I installed CyanogenMod 7 (Android v2.3.7) without any problem,to do this you must have a root phone, ROM Manager installed in phone and must install clockworkmod
