Vodaphone or Motorola
Old Member
Android Expert
Has anyone else noticed that our phone is listed as a Vodaphone in the Play Store? Why is that?
[/URL]
Mine is listed as "Droid Maxx". Though in the past I have seen it listed as "XT1080M". I don't ever recall seeing Vodafone, though.
In the devices listing, my phone's carrier is Verizon.
Are you rooted or stock?
I suppose that you could try going into settings->apps, find Google Play Store, tap it and then tap "clear data" (or "uninstall updates" if "clear data" doesn't work). Go back into Play Store, accept the terms, update or install something, and see if it changes in the Play Store settings.
