voice call volume control disabeled
jocorok
I found a problem with skype. The audio is very quiet.
I went investingating. Since the youtube videos were loud enough, there is only problem with skype.
I installed audiomanager app and I can see that "voice call" volume was set to 4/15. The problem is that the slider can't be moved. I can move the sliders for system, notification and media sound sliders, but "voice call" slider is disabled or stuck.
I also tried other audio setting apps, but no success.
So it seems that the voice call volume control is somehow disabled and there is no way to change it.
Android 4.1, q-pad.
Do you have any ideas what's going on here?
P.S. The same audiomanager tool works great on my galaxy nexus, android 4.2.
THX,
Rok
