Voice Changer
kentz19
Good day!
I just want to ask if there are any android apps that could change the voices of people, like when calling someone.
Please do share it!
Thanks!:)
Thanks for the information!
Can you suggest what sites where in we can download free android apps that are free from this malicious acts?
Thanks!:)
I usually stay away from apps that have a low rating or have less than 1000 ratings (and or reviews).
I've used Google Play, Amazon and AppBrain and been fine for 2 years.
Amazon offer a Free App of the Day program (you only have to install their Appstore to access it) where each day they make a paid version free for a day. They are of varying quality but I've had some good titles from it.
It also wouldn't hurt to put in an antivirus app so that you won't have to worry. Even protected apps stores can have some filth lying around.
Thanks for the reminder INvinter23!
I'm planning to download AVG as my ANti-Virus.
Do you think its effective? Because that is also the anti-virus that we are using in our PC, but I'm also planning for Avast.:)
What would you refer?
I use AVG on my Android and Desktop, it works pretty well on an Android. :cool:
Hi, Kentz19! Try Best Voice Changer app. Record yourself and then change your voice. Select many voices and effects. You can also change the background sound; make it sound as if you are on a plane, during battle and more. Features: ★ Change your voice to CHIPMUNK, CAT, ROBOT, CHILD, MEGAPHONE, serveral WOMEN's and MEN's voices, and more★ Add Effects: CHORUS, ECHO★ Add Background sounds: AIRPORT, BATTLEFIELD, CROWD, RAIN, STREET, AIRPLANE ★ Change your SPEECH SPEED★ If you liked Ultra Voice Changer and Voice Changer Deluxe you will like this app better★ Instantly hear the modified voice★ Save recordings as WAV files, come back and change it later.
