Voice control widget: Quick audio settings
matto87
Hello.
I just want to let you know about application I made a few weeks ago. It is called Quick audio settings. If you would like to change your audio profile settings right on your home screen widget, then it is application you need.
Here is link for downloading it from market.
And here is link to my home page.
If you need QR code, here it is:
Try it, its free.
Here is description.
Application Quick audio settings helps us to quickly and easily manage audio settings.
Features:
-Home screen widget
-switch between ringer modes(Normal, Vibrate, Silent)
-Mute and unmute your phone
-Vibrate or not
-adjust ringtone volume
-detailed notification settings
We can switch between:
-MUTE WITHOUT VIBRATION,
-MUTE WITH VIBRATION,
-RINGTONE ON WITHOUT VIBRATION,
-RINGTONE ON WITH VIBRATION.
We are able to change settings for NOTIFICATIONS, RINGER or both.
The included widget can switch between 4 basic settings(audio profiles) for NOTIFICATIONS and RINGER. If we want to go into details there is a button which opens main app.
