Help Voice dialing question
GaryS1964
Member
I use Vlingo as the app to connect my Captivate to my bluetooth device. The bluetooth device is basic and does not store numbers. I want to be able to dial numbers via voice command but it only seems to work on very few numbers stored in my phone contacts and absolutely will not dial a number that is not in my contacts.
What am I doing wrong or is the a limitation of the Captivate.
BTW - I'm using Gingerbread.
Hi GaryS - I moved your thread into the Support & Troubleshooting area in the hopes that someone in here will be able to help you. (Unfortunately, I do not have this device so I can't help out)
