Call yourself from another phone and leave yourself a short message. Then go into your voicemail and listen to and delete the message you left yourself and the problem will be resolved. Good luck.I've tried to find this before posting but all suggestions have not worked for the LG Marquee. The voicemail indicator will not disappear from the status bar. I've tried rebooting, removing the battery all to no avail. Has anyone else encountered this before?
Thank you so much for the useful explanation, I won't make that mistake againI can confirm this will work. :thumbup: The key is waiting until the notification clears after you delete the voice mail (before you hang up)
If you delete the vm, then hang up immediately, the phone doesn't receive the signal that you have no voicemail. Then when you call back to try and clear it, there isn't a voicemail to delete, so it can't send the signal to dismiss the notification.
did you try force stoping it?I've tried to find this before posting but all suggestions have not worked for the LG Marquee. The voicemail indicator will not disappear from the status bar. I've tried rebooting, removing the battery all to no avail. Has anyone else encountered this before?
