neutrino68
Soon after upgrading to 2.2, I received a "voicemail pending" in the notification bar. I clicked on it and it dialed voicemail, which asked me to personalize and set up my voicemail (pin #, etc.). I did all that and now the notifcation will not go away.
Also, the "Clear" button is gone. The "Clear" button comes back if there is another new notification like a text msg or a new voicemail. Then you can press clear and everything goes away except for "voicemail pending"! When you press on the notification now it just dials voicemail which tells you that you have no new voicemail!
I saw one older thread on this which was unsolved. Does anyone know if this is a 2.2 bug? Any way to force clear the notification bar?
My device: Samsung Intercept - Sprint
Thanks
G
Thanks
G
