realdreams
Member
This is a Sprint prepaid LG Volt activated on RingPlus.
I keep getting the Voicemail important update notification.
Check for update
Important Update!
This is a Mandatory software update due to the age of your current version.
- It includes Ads and Free Avatar Messaging. However, both can be disabled in the Setting Menu.
- There is no charge to use Avatar Messaging unless you choose to purchase premium content.
After clicking 'Update', I always get an error message, "Sorry, there was a problem checking for update".
The version I have is T.5.3.4.32. I read it's a common problem for Sprint phones activated on MVNOs because the visual voicemail is not supported on those MVNOs like Ting.
I just unchecked "show notifications" for voicemail app. Is there a better solution?
I do not use the voicemail from the carrier at all (Google voice instead). Is it safe to disable/remove the voicemail app (does it prevent me from doing further OTA?)?
Check for update
Important Update!
