Help volt battery drain, part 2
erician
Member
LG Volt 4.4.2
- replace battery with new, check
- remove "battery dr" and anti-virus-type apps, check
Still, my battery's hemorrhaging power
What to do?
Only 2 things I can think of. Your phone is far from cell towers and is using maximum power or some other Apps or process is always running. Go into your settings and check what is using the most battery.
