Help VoLTE
SUSS
Does anyone know where to turn this off on a Vodafone s6 edge? Is it even an option.
I'm having drain issues with cell standby and have read turning this off helps. Sadly can't see the option on my UK phone. Anyone have any ideas?
Thanks in advance.
Thanks in advance.
According to several articles, to disable volte, go into your phone app, select more in top right and option should be there to disable.
It's not there, I'm assuming it's not enabled or hidden on the Vodafone model.
Also looked in wifi and nothing there.
Nor for me either on my verizon s6 edge after just looking.
I'll do a little more research and post here if I find anything else.
Alright, unless there's a special code you can dial to get into hidden settings, can't disable volte.
The option to do so use to be under the call settings before it got removed.
