Yes, IF you have installed a newer version of CM7 (certain builds after 7.03 stable that have the .32 kernel) AND have Dalingrin's kernel, you can install Nook Color Tweaks that will allow you to overclock the cpu and adjust the volume.
Installing the app will tell you if you have the required other parts.
