My dad somehow changed his volume control, so it only affects the media volume. Any clue on how to change it back? Instead of Ringer Volume, it says Media Volume on the box that pops up when pressing the volume controls.
If you are in an app that is considered media ie music, Yup tube etc, it will always say media volume. Otherwise on the home screen it should say ringer volume.
Happened to me. If you are using a task killer, make sure anything that uses media volume is closed. Then I just turned it off and back on. It was back to call volume. I found this answer somewhere else on the forum, but I couldn't find the link.
