Help Volume Down button "stuck" - Can't get out of hboot now - Looking for help
Helpzors
While my phone was on the volume would turn all the way down and keep vibrating like it was being pressed repeatedly. I was able to press volume up but after releasing the button it would go straight back to the vibrate option and keep vibrating like the volume down button was being pressed. The vol. up and down both feel like they work physically and each have the same response tactile wise so I know its not physically stuck.
My next step was to take the battery out but this is where the plot thickens... We have a teething 9 mo. old and when I took the case off I noticed some moisture. I generally try to keep the phone away from him but did i mention he was a teething 9 mo. old?
After taking the battery out and waiting for a few minutes I replaced the battery and tried to turn the phone on. You can probably guess what happened next... It goes straight to hboot because the phone thinks im pressing the vol. down button with the power button.
Now while in hboot I am able to navigate via the vol. buttons but the selection only goes down if I press either the vol. up or down buttons. I try to make a selection with the power button but it gives no response. probably because i still thinks im pressing the vol. down button.
This is where I am at now. Any help would be appreciated!
