Help volume issues
admob
Hi, as the title suggests I keep losing volume on my tf, it needs a reboot to correct it. Anyone else with similar problems/solutions... ta.
I opened a trouble ticket with Asus on this issue plus the reboot cycle issue. They told me to do a data wipe on my tablet and then install each app one by one. I did this on Tuesday. As of today, I haven't had either issue. I won't feel entirely convinced that this would fix my issue unless I am problem free by next Wednesday. I've managed to go up to 3 days without issues before. I figure a full week plus a day would be a good indicator that it is fixed. I intend to post back by then if everything is OK.
I had the reboot issue again today. I didn't experience the sound issue. Usually, a reboot resets the sound issue, so at least it went 4 days without the sound issue.
The sound issue also hit my TF after I rebooted it manually. But then I saw the Asus control widget in the notifications area and it was on silent mode (I did NOT select silent mode, it did this all by itself). Turning silent mode back off solved it, no need to reboot the tablet.
Maybe you could check it when you encounter this issue.
My TF101 had no sound today when I started using it, rebooted the TF101 and it and the sound came back...
