I droped my samsung galaxy centura out of my pocket and the volume does not work.it only vibrates.It wont ring or any thing.went into the settings and got avery thing as loud as it will go.But still dosnt work?
Does the earphone socket still work? (with earphones) If so, then its probably the speaker or the connections to it which are damaged. It may be repairable. If there is no sound singnal to the socket either, its probably more serious.
I just checked the earphone socket and it works.So like you said its the speaker or conn.How do i reboot it.I did it long time ago,but cant rem how to.The only thing about reboote is all my pictures and contacts are eraced.I can send my pictures to another phone and after i reboot it,i will send my pictures and video back to my phone.And thanks for your help with this.
By reboot, I just meant turn it off, take the battery out for a minute and put it back and restart. You are thinking of a factory reset! That may help but I'm not sure... If you do try a reset:
Best thing with pictures is to sync them with dropbox or google drive (both might take a while on wifi depending on how many you have) before you do it. Contacts will be saved automagically so long as the are google (not phone or SIM) contacts.
