Help Volume problem on the warp 7
Warp7user
OK I just got this phone and noticed the volume isn't that high when it's turned up all the way. I went and downloaded a volume booster app and it showed the real volume of the phone when set on 100 percent is like 86 percent and 90 percent. I turned it to 100 percent Max volume and it's still low. It works great with headphones but when you have no headphones connected the volume just isn't good.. It even has a Dolby equalizer as a system app so I'm not sure if the decreased volume by default has anything to do with the Dolby equalizer. The Dolby equalizer only has a few settings and it's missing a bass booster. I'm trying to get into Google Play musics equalizer to use it but it just opens Dolby's equalizer. I don't have root so I can't do any system modifications so I'm not sure what my options are without root or a custom rom.
oh, so you have noticed it as well? volume feels like it is set to 80% at max or something. lol
and there is no root at the moment. I have been searching for a method but have come up empty handed each time.
I have also experienced a problem where I get a volume up/down sound randomly.
and it isn't even a notification.
