Volume Settings - A 7.1.2 - Aquaris M5.5
I want to have the ringer silent, with no vibration, and be able to set all other volume controls as I prefer.
I never accept calls, but want to be alerted, when I receive notifications from some specific apps, by a sound.
I am using a BQ Aquaris M5.5 mobile phone.
It appears the BQ brand no longer exists (I have been gifted the device).
Is it possible to upgrade the os?
Android version: 7.1.2
Kernel version: 3.10.49-g5190b11
Build number: 5.2.0_20180228-1302
Thanks.
Thanks.
not unless there is an official update release from the manufacturer. this is the problem with off brand phones. they will never get support. if there are no updates for the phone, you are stuck with what you got.
you should have a separate ringtone volume, if you do not then i do not know what you can do, other then get a new phone.
The company no longer has a website. I think they stopped trading this year.
There are separate ringer and notification volume controls, but if the ringer is set to zero, the notification level is also then changed to zero, automatically. I have tried three volume control apps, but they do not work.
was this always the case? or just recently? anyways i don't know what else to tell you other than a factory reset....or get a new phone. this will always be the case for off brand phones.....so buyer beware.
