vpn client to work like Juniper?
cyberpine
My employer has juniper vpn client. There is apparently no client for the Android, however android does offer vpn configuration. Which should I chose, pptp, l2tp, l2tp/ipsec psk, l2tp/ipsec crt?
Juniper put out the Junos Pulse client. It works, but only within the application. It's not a true VPN in the way of allowing other applications to use the network. Juniper is saying the limitation is due to some Android OS limitation.
