Help Vpn how to?
Welcome to Android Forums, klamaa.
I've moved your question to the Xperia X10 area for you.
Hi Klamaa and welcome here!
These are the instructions for Android 2.1, if you still have 1.6 it might be a little different but look around the settings and you'll find it.
Go to Settings > Wireless and Networks > VPN Settings > Add VPN.
That's it!
If you have 1.6 here is the process:
Settings > Wireless Controls > VPN Settings > Add VPN:
Add PPTP VPN / Add L2TP VPN / Add L2TP/IPSec PSK VPN
Choose which one you want to modify, select it and then follow the various prompts on the page.
Good Luck...........
