Help Wallpaper wont fit and widgets wont refresh
Tab88
Hi all, happy new year.
I'm using Go Launcher Ex with firmware 4.0.3 and have started noticing glitches appearing (no recent updates or new apps installed). One annoying thing is the wallpaper has suddenly stopped covering the bottom cm of the screen, leaving just a black bar across the bottom (applies to stock wallpapers too, checked all settings) - to anyone using Go Launcher this means that only half the dock bar is covered, the other half is black.
Also, my battery widget stopped refreshing so I tried various others but now none are working.
My tab is not rooted, am careful what apps I install, have virus-checked and gone through all settings with no joy. Anyone any idea what's happening and how I might be able to fix it?
Thanks in advance for any suggestions.
