Wallpapers issue
imedo
Member
I got a few cool wallpapers for the lock screen but whenever I try to set one on my phone I have to crop it and that's horrible,is there any thing I can do ?
Which phone do you have? My Nexus forces me to crop whether I use a photo or an app. It could be a screen resolution problem.
What size is the image you want to use, and what size is your phone's resolution?
It sounds like the picture is too big and you want to scale it down rather than crop it (I assume you're not getting the choice) If that's the case then try scaling it down first so it is the same size as your resolution.
If the image and resolution are the same size then you shouldn't have to crop it...
