I am getting like 15 calls a day from the same telemarketer number. and I was wondering if there is a way to block or ignore that number so my phone doesn't ring or vibrate when that number calls?
You can set up most Android phones to send numbers straight to voicemail so your phone doesn't ring when they call. While this doesn't completely block them it can be helpful.
1. Add the number to your contacts.
2. While viewing the contact tap Menu.
3. Tap All Calls To Voice Mail.
Note the steps might be slightly different depending on your phone (I'm not using the Ultra). For example: View Contact > Menu > Options > then check the option to send directly to voicemail.
