Help Want to update 2.2 with help
Hello All,
I want to update my samsung galaxy s with froyo 2.2, but need help. I am not a computer friendly.
Can any body help me?
Please let me know the simple step by step procedure.
Thanks in advance.
With Regards,
Indrajeet
Hello, there are plenty of posts asking the exact same question with someone replying into them, so next time, please do a bit of search before creating a thread.
Here is one:
You have to update via KIES, there is no other official way.
Here is what you have to do:
1) Uninstall any lagfixes from your phone (if you have any)
2) Just to be sure make a backup of anything you don't wanna risk losing
3) Connect your phone, open Kies, wait for it to recognize your phone
4) Click Firmware update and go from there
If it is not in your country yet and says no update available, follow the steps in this post on XDA.
Enjoy your new official Froyo!:)
Here is one:
thanks for your reply but kies is not working properly. i want to update without using of kies.
is there any other way to update?
Regards,
Indrajeet
I have had loads of trouble with Kies.
Connection is hit and miss and when it has connected and I try to update, it gets half way through the process and then says MCS Thunder has encountered a problem and needs to close. this action then freezes my pc and phone.
Today it took me 2 hours to get my pc running again because Kies was F***ing it up on restart:mad:
Anyway, I contacted Samsung support and this is the reply I got.
Thank you for contacting Samsung Electronics.
Regarding your case, please note the following tips to connect successfully:
oh that's awesome maybe i if they actually bother to let us tmobile users have the update ill get it sorted.
The local service centre update depends on where you live. I imagine that they will only help your to update to froyo if you happen to live in Norway or Sweden.
Everyone else, if KIEs not working for you, use ODIN.
So it seems there is another way to get the updates.
I'm going to call my local service centre on Monday, see what they say.
Did you give them a call? I might try tomorrow and see what they say. I'm fed up of having to wait for an update that's I should have gotten already.
