Root Warhead rom
goddi
anyone else having trouble with the dialer with this app? It well fc on me and hang up calls and place people on mute and hold.any known issues?
try take5. take5 is the latest 1.6 bh_man rom and it might fix your problem
or you could try micohax's tweaked 1.6 rom. its really good and it WILL fix your problem.
all the touchwiz roms have an FC problem because it was a good attempt to make 1.6 run on the phone before Samsung released the OEM 1.6 update.
Microhax's tweaked rom uses the OEM update from samsung so it fixes the hang up FC problem
