Apps Warping the Android UI for a curved screen
zaidmo
I'd like to know how I can warp (perform geometric correction) of the entire Android UI for projector display onto a curved screen.
OpenGL is a core library on the Android platform and I know that OpenGL ES allows for mapping of each screen frame as a texture to a user-defined mesh grid.
http://developer.android.com/guide/topics/graphics/opengl.html#coordinate-mapping
How can I leverage this to transform the entire UI (across all apps & themes) as per the attached image?
I've been trying very hard to get an answer & developer to help me on reddit, xda, upwork & freelancer (I'll pay for this) https://www.freelancer.com/projects/Software-Architecture/Android-Warping-Custom-Geometric/#/details
I've also looked into the wearables api's but that seems to be limited to individual apps and doesn't do warping.
If I can't warp the entire UI then I'd like to perhaps warp and display each frame from the Android TV HDMI-In. The SDK doesn't seem to leverage Open GL. Can I override it and do the transformation? https://source.android.com/devices/tv/
Can someone here assist or guide me?
Regards
Zaid
Did you find anything close to your needs on Android market? Some good example app. What Im saying is that you can write to a developer over there you know .. It just one more option if you tryED like everything.
