So I fell in a river over the weekend and my phone had the pleasure to come with me. Because it's an Lg G2 ripping out the battery wasnt an option, so I did what I could for it. I pulled off the back, got what water I could out of it and dried it with a dryer the best I could.
Eventually I got it working again. I dried the phone out and turned it on and it works perfect except one issue. Found that the screen had a white middle and gray around edges. (Like its dimmer around edges). It appears water is either in LCD or between digitizer and LCD. The gray area is uniform in brightness and looks normal (except its dimmer than usual but not by much) I figured that was water so I put it in a handy electronics dryer at work set to 115F during day and rice at night. Well all it's done is make the gray spread more and more and now 90% of screen is gray with a little white left right in the middle. Touch screen works perfectly.
So does anyone know what the issue is? Is the gray area water? Should I take apart the phone and remove battery and soak in iso alcohol? Any suggestions would be a big help!
